주요 콘텐츠로 건너뛰기
Logitech M215 Top Cover Replacement
필요한 것
  1. Logitech M215 Top Cover Replacement, Remove the battery cover: 1 단계, 이미지 1/3 Logitech M215 Top Cover Replacement, Remove the battery cover: 1 단계, 이미지 2/3 Logitech M215 Top Cover Replacement, Remove the battery cover: 1 단계, 이미지 3/3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Top Cover Replacement, Remove old battery: 2 단계, 이미지 1/1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Top Cover Replacement, Top Cover: 3 단계, 이미지 1/2 Logitech M215 Top Cover Replacement, Top Cover: 3 단계, 이미지 2/2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Top Cover Replacement: 4 단계, 이미지 1/1
    • Pry the top cover off. You may need to use a pry tool to help.
결론
Hannah Pate
회원 가입일: 01/30/15
1,734 평판
안내서 7개 작성하였습니다
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S1G1
4 회원들
안내서 28개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 2,666
