주요 콘텐츠로 건너뛰기
Logitech M275 Scroll Wheel Replacement
필요한 것
  1. Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
    • Flip the mouse over.
    • With your fingers, gently press down and remove the battery cover.
    • Remove the battery and the USB receiver from the mouse.
  2. Logitech M275 Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Logitech M275 Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the sticker at the bottom of the battery compartment.
    • Use a Phillips screwdriver to remove the single screws at the bottom of the battery compartment.
  3. Logitech M275 Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the top half of the mouse cover.
  4. Logitech M275 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech M275 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger or screwdriver to carefully apply upward pressure around each side of the circuit board until the whole piece slides out of the bottom.
  5. Logitech M275 Scroll Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Using a soft cloth, gently remove dust and small debris.
  6. Logitech M275 Scroll Wheel Replacement: 6 단계, 이미지 3개 중 1개 Logitech M275 Scroll Wheel Replacement: 6 단계, 이미지 3개 중 2개 Logitech M275 Scroll Wheel Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the wheel from its axis and replace it with the new wheel.
  7. Logitech M275 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 1개 Logitech M275 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 2개 Logitech M275 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 3개
    • Ensure that the new scroll wheel is aligned with the encoder.
    • Make sure that the new scroll wheel spins and clicks into place.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Adrianna Doan
회원 가입일: 05/12/25
145 평판
안내서 1개를 작성함
UC Davis, Team 2-4, Whithaus Spring 2025 UC Davis, Team 2-4, Whithaus Spring 2025 회원
UCD-WHITHAUS-S25S2G4
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 59
전체 시간: 476
