주요 콘텐츠로 건너뛰기
Logitech M325 Scroll Wheel Replacement
필요한 것
  1. Logitech M325 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 1개 중 1개
    • Caution: Before you begin, ensure that the mouse is powered off (red color displayed on the switch). The switch can be found at the bottom of the mouse.
    • Remove the battery cover from the bottom of the mouse by sliding downwards.
  2. Logitech M325 Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Logitech M325 Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Lift out the AA battery.
    • Remove the USB adapter.
  3. Logitech M325 Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Peel off the sticker in the battery compartment to reveal the screw underneath.
  4. Logitech M325 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech M325 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the 5 mm screw in the battery compartment.
  5. Logitech M325 Scroll Wheel Replacement: 5 단계, 이미지 2개 중 1개 Logitech M325 Scroll Wheel Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the lower case downwards and separate the top case from the main mouse body by lifting it off.
  6. Logitech M325 Scroll Wheel Replacement: 6 단계, 이미지 2개 중 1개 Logitech M325 Scroll Wheel Replacement: 6 단계, 이미지 2개 중 2개
    • Use a pry tool to unclip the scroll wheel from the PCB by pushing the clip out of the holder.
    • Remove the scroll wheel by lifting it up.
  7. Logitech M325 Scroll Wheel Replacement: 7 단계, 이미지 2개 중 1개 Logitech M325 Scroll Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Align the replacement in the same position as the old scroll wheel.
    • Push down and clip in the scroll wheel.
  8. Logitech M325 Scroll Wheel Replacement: 8 단계, 이미지 3개 중 1개 Logitech M325 Scroll Wheel Replacement: 8 단계, 이미지 3개 중 2개 Logitech M325 Scroll Wheel Replacement: 8 단계, 이미지 3개 중 3개
    • Align the top housing clips with the mouse body clip openings.
    • Slide top housing back onto mouse by pushing it in.
결론
To reassemble your device, follow steps 1-4 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
mykayat_YU
회원 가입일: 01/09/25
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 343
