주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M330 Wireless Mouse Wheel Replacement
필요한 것
  1. Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: 1 단계, 이미지 3개 중 1개 Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: 1 단계, 이미지 3개 중 2개 Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: 1 단계, 이미지 3개 중 3개
    • Turn your mouse over with the scroll wheel facing down.
    • Flip the ON/OFF switch on the bottom of the mouse to turn it off.
    • Slide the battery cover off.
    • Remove the battery and unplug the USB receiver.
  2. Logitech M330 Wireless Mouse Wheel Replacement: 2 단계, 이미지 3개 중 1개 Logitech M330 Wireless Mouse Wheel Replacement: 2 단계, 이미지 3개 중 2개 Logitech M330 Wireless Mouse Wheel Replacement: 2 단계, 이미지 3개 중 3개
    • Use tweezers to peel back the battery sticker cover.
    • Use a JIS #00 screwdriver to remove the single 3.1 mm screw from the battery well.
  3. Logitech M330 Wireless Mouse Wheel Replacement: 3 단계, 이미지 2개 중 1개 Logitech M330 Wireless Mouse Wheel Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a plastic spudger in the seam between the top and bottom shell, starting at the back edge.
    • Slide a plastic spudger or opening pick around the edge to carefully release the clips.
    • Gently remove the bottom plate from the top cover.
  4. Logitech M330 Wireless Mouse Wheel Replacement: 4 단계, 이미지 3개 중 1개 Logitech M330 Wireless Mouse Wheel Replacement: 4 단계, 이미지 3개 중 2개 Logitech M330 Wireless Mouse Wheel Replacement: 4 단계, 이미지 3개 중 3개
    • Use a JIS #00 screwdriver to remove the 1.5 mm screw securing the board to the case.
    • Gently remove board from bottom plate.
  5. Logitech M330 Wireless Mouse Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the scroll wheel from the shaft, taking note of any spacer or washer arrangement.
    • Install the new wheel, ensuring it spins smoothly and provides the expected tactile click.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
Adam Ward
회원 가입일: 09/29/25
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 24
지난 30일: 80
전체 시간: 192
