주요 콘텐츠로 건너뛰기
Logitech M570 Wireless Trackball Disassembly
필요한 것
  1. Logitech M570 Wireless Trackball Disassembly, Schrauben lösen: 1 단계, 이미지 1/1
    • 5 Schrauben lösen, die teilweise versteckt sind. Drei Schrauben befinden sich unter den Gummipuffern und eine im Batteriefach unter dem Aufkleber (den sollte man dann vorher lösen)
    • Den blauen Trackball kann man einfach aus seiner Halterung herausdrücken. Das sollte man auch gelegentlich tun und die Öffnung reinigen.
  2. Logitech M570 Wireless Trackball Disassembly, das Innenleben: 2 단계, 이미지 1/2 Logitech M570 Wireless Trackball Disassembly, das Innenleben: 2 단계, 이미지 2/2
    • Nachdem die Schrauben gelöst sind, lässt sich das Gehäuse leicht abheben. Die Aufnahme für den blauen Ball besteht aus einem eigenen Stück Kunststoff. Die Platine ist mit einigen Schrauben befestigt.
결론
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 7명이 해당 안내서를 완성하였습니다.
Peter Scholl
회원 가입일: 06/26/21
1,440 평판
안내서 6개 작성하였습니다
AEG-Make&Repair AG AEG-Make&Repair AG 회원
Local Repair Groups
3 회원들
안내서 12개 작성하였습니다
댓글 6개
Had an issue where the left clicker was not working great anymore. Followed this guide to take it a part did a little blow out and some rubbing alcohol to for now restore it to the proper working condition! Thanks as I would have never found the screw under the battery sticker.
Jamie Lawson - 답글
Great! Thanks for the feedback - it's really motivating
Peter Scholl -
Hi, the middle click on my M570 was working really bad, sometimes works sometimes not.. but after open the mouse and apply isoprophilic alcohol with a soft brush in the middle switch (the square with red central button), it is working like a charm again.
mouse working again - 답글
Thanks for the information. I am happy you could use the information
Peter Scholl -
More than happy to find this manual, as I was asking official Logitech Support and no positive answer. I disconected the tape between teh upper and lower part - any tips how to reconect it?
I would also never find the fifth the screw under the battery sticker.
Piotr Pawłowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 52
30일 전: 229
전체 시간: 5,661
