주요 콘텐츠로 건너뛰기
Logitech M570 Wireless Trackball Mouse Microswitch Replacement
필요한 것
  1. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Unscrew 5 screws, which are partially hidden. Three screws are located under the rubber buffers and one in the battery compartment under the sticker (which should then be loosened beforehand).
    • You can simply push the blue trackball out of its holder. You should also do this occasionally and clean the opening.
  2. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: 2 단계, 이미지 2개 중 1개 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: 2 단계, 이미지 2개 중 2개
    • After the screws are loosened, the housing can be easily removed. The space for the blue ball is made of its own piece of plastic. The circuit board is held in place with a few screws.
  3. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Detach trackball holder from circuit board: 3 단계, 이미지 1개 중 1개
    • Lift the gray latch and pull the flat cable out of the connector. The trackball holder can then be placed to the side.
  4. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: 4 단계, 이미지 2개 중 1개 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: 4 단계, 이미지 2개 중 2개
    • Unscrew four Phillips screws (orange) and lift circuit board out of housing, being careful with the wires holding the battery, but these can be lifted out of the housing without further unscrewing.
    • The switch for switching on should not be lost in the process (see second picture)
  5. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Microswitch replacement: 5 단계, 이미지 1개 중 1개
    • Properly desolder the microswitch (green) at its three contacts
    • Solder in new microswitch, making sure that it sits flat on the board.
  6. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Reinstall the circuit board: 6 단계, 이미지 1개 중 1개
    • Make sure that the small circuit board with the two buttons with the hole in the middle (green) is placed over the holding pin. Then it is in the correct position.
결론
Work through the steps in reverse order to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Peter Scholl
회원 가입일: 06/26/21
1,818 평판
안내서 7개를 작성함
5가이드 댓글
Where I would been able to buy the microswitch?
Torpedo Javi - 답글
I soldered it out from an old mouse... but I think you will also get it on ebay
Peter Scholl -
This guy shows replacement switches fixing a newer version of same trackball(I think). It has a built in battery now.
Replacement switches he used from ALIEXPRESS.
I think I'll try those. I've had switches lose there mechanical springy-ness and also get where they don't work reliably on 2 or 3 trackballs.
https://www.aliexpress.us/item/325680110...
https://michael.stapelberg.ch/posts/2021...
Spruce Moose Tomato Juice - 답글
Ich konnte bei mir im Fundus eine Maus (DELL M-UVDEL1) finden, welche einen sehr ähnlichen Taster verwendet; diesen konnte ich erfolgreich verpflanzen :-)
Michael-01 - 답글
Danke für die Rückmeldung - freut mich, wenn die Infos Menschen auf Ideen bringen bzw. weiter helfen. Viele Grüße!
Peter Scholl -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 58
전체 시간: 5,058
