주요 콘텐츠로 건너뛰기
Logitech MX Keys Key Removal and Replacement
필요한 것
  1. Logitech MX Keys Key Removal and Replacement, Take out key: 1 단계, 이미지 1개 중 1개
    • Insert something thin under the top of the key.
    • Apply a little force. It comes out easily.
  2. Logitech MX Keys Key Removal and Replacement, Anatomy of a key: 2 단계, 이미지 2개 중 1개 Logitech MX Keys Key Removal and Replacement, Anatomy of a key: 2 단계, 이미지 2개 중 2개
    • Anatomy of a key
  3. Logitech MX Keys Key Removal and Replacement, Put key back: 3 단계, 이미지 2개 중 1개 Logitech MX Keys Key Removal and Replacement, Put key back: 3 단계, 이미지 2개 중 2개
    • Slide in bottom first
    • Gently push the top part in. It clips easily.
결론
You've successfully removed and replaced a keycap on your Logitech MX Keys keyboard.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
sitarane
회원 가입일: 09/10/15
996 평판
안내서 1개를 작성함
24가이드 댓글
Do you think the clips are durable?
Joshua M - 답글
No, they break easily.
ikomrad -
Where can I find the keys for the replacement? I can only find keys for like $15 per key...
Fritz Freund - 답글
I need to know this too!
ikomrad -
If you are having sticky key issues, take the key out, clean out the area beneath the key, and underneath the key, and reinsert the same key. In most cases, this will fix your issue. This may happen if debree/dust gets in-between the keys.
Gitesh Agarwal -
댓글 쓰기
조회 통계:
지난 24시간: 53
지난 7일: 612
지난 30일: 2,699
전체 시간: 67,193
