소개
Use this guide to safely remove and replace the battery in a Logitech MX Vertical wireless mouse.
Note: If your battery is swollen, take appropriate precautions.
Accessing the battery requires removing the adhesive feet on the mouse’s underside. If thoroughly heated, they can be cleanly removed, but you may need replacement feet if one rips or some of its adhesive is left behind.
필요한 것
Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
Insert one arm of a pair of sharp tweezers underneath the end of one foot.
Grip the foot and begin to peel it away from the bottom of the mouse.
Use a Phillips screwdriver to remove the five 6.5 mm recessed screws securing the two halves of the mouse casing together.
Lift the top half of the mouse away from the bottom half.
Lay the top half of the mouse, buttons down, onto your work surface.
Use a pair of blunt tweezers to grip the edges of the battery cable connector, and pull up to disconnect it from the motherboard.
Peel the battery away from its shelf.
Remove the battery.
Remove any leftover adhesive from the battery shelf.
Apply double sided tape or pre-cut adhesive to secure the new battery.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 7개
¡Excelente guia! ¡Parece haber sido hecha por el fabricante! ¡Muchas gracias!
Is it actually important to replace with the same mAh value?
Or can I go with something bigger as long as the voltage is 3.7V, the connector is the same and the battery actually fits inside the mouse?
You can find the replacment battery here: https://www.cutratebatteries.com
Just search AHB521630PJT-04
You're welcome!
