주요 콘텐츠로 건너뛰기
Logitech Mouse G302 Disassembly
필요한 것
  1. Logitech Mouse G302 Disassembly, Open the case: 1 단계, 이미지 2개 중 1개 Logitech Mouse G302 Disassembly, Open the case: 1 단계, 이미지 2개 중 2개
    • Flip the mouse over to gain access to the bottom.
    • Using a scalpel, pick, or similar tool, peel away the slide pads on the bottom of the mouse in order to expose the three screws.
    • Using a PH0 / Phillips #0 driver, remove the 3 screws shown in red.
    • Peel away as little of the pads as possible, in order to preserve the adhesive on their undersides.
    • Gently separate the two halves of the case. Light prying may be required.
    • For PCB removal : remove 3 PH0 screws from PCB surface. The whole PCB can be taken out for inspection and repair after the screws are removed.
  2. Logitech Mouse G302 Disassembly, Switch replacement: 2 단계, 이미지 2개 중 1개 Logitech Mouse G302 Disassembly, Switch replacement: 2 단계, 이미지 2개 중 2개
    • The switch's brand is Omron. Part number: D2FC-F-7N. Components have 3 pins leaded type (two utilized)
    • I experienced one switch working intermittently. In such case, I recommend replacing both L & R switches.
  3. Logitech Mouse G302 Disassembly, Switch information: 3 단계, 이미지 1개 중 1개
    • This is helpful for finding the correct replacement or compatible replacement e.g. vendors from online store AliExpress.
    • I used this as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufacturer is Omron, manufacturer part number is D2F-F.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Carsten Dahl Hjarup
회원 가입일: 11/04/13
3,116 평판
안내서 9개를 작성함
2가이드 댓글
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - 답글
Did the job on my own mouse just tonight. The screws are actually Phillips #000, not #0 as indicated in the guide.
Michael G - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 98
전체 시간: 6,651
