소개
1- Remove the cover where you replace the battery.
2 - Below each battery, there is a screw that you remove with a small Philips screwdriver.
3 - At the top of the back part of the mouse there are two rubber finishes that you remove (it has an adhesive) and there you will find the screws that hold the top.
4 - It gets loose immediately, please be careful with the wire that connects one part to another, please disconnect this wire.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
