주요 콘텐츠로 건너뛰기
Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement
필요한 것
  1. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 1/3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 2/3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 3/3
    • To remove the plastic cover, use the plastic opening tool at the corner of the device.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Caution: Carefully remove the cover as it is easy to break.
  2. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 2 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 2 단계, 이미지 2/2
    • Remove the eight 10.5 mm Phillips #1 screws securing the cover.
    • Remove three 5.2 mm Philips #1 screws securing the dock.
  3. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 3 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 3 단계, 이미지 2/2
    • Use the metal spudger to loosen the front cover to get into the inner part of the device.
    • Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure to carefully lift up the front cover from the back cover.
    • There are wires connecting to between battery and the cover.
  4. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 4 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 4 단계, 이미지 2/2
    • Identify the small circuit board attached to the dock adapter cover.
    • remove two 2.5 mm Phillips #1 screws at the circuit board.
  5. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 5 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 5 단계, 이미지 2/2
    • Carefully take out the dock adapter cover from the device.
    • It might needs few try to pull out the small circuit board.
    • Take out the broken dock adapter cover and replace with the new one.
결론
ali alhashim
회원 가입일: 07/18/18
121 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S4G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 825
