주요 콘텐츠로 건너뛰기
Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement
필요한 것
  1. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 3개 중 1개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 3개 중 2개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 1 단계, 이미지 3개 중 3개
    • To remove the plastic cover, use the plastic opening tool at the corner of the device.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Caution: Carefully remove the cover as it is easy to break.
  2. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 2 단계, 이미지 2개 중 1개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 10.5 mm Phillips #1 screws securing the cover.
    • Remove three 5.2 mm Philips #1 screws securing the dock.
  3. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 3 단계, 이미지 2개 중 1개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Use the metal spudger to loosen the front cover to get into the inner part of the device.
    • Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure to carefully lift up the front cover from the back cover.
    • There are wires connecting to between battery and the cover.
  4. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 4 단계, 이미지 2개 중 1개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Identify the small circuit board attached to the dock adapter cover.
    • remove two 2.5 mm Phillips #1 screws at the circuit board.
  5. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 5 단계, 이미지 2개 중 1개 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully take out the dock adapter cover from the device.
    • It might needs few try to pull out the small circuit board.
    • Take out the broken dock adapter cover and replace with the new one.
결론
작성자
3다른 기여자 명과 함께
ali alhashim
회원 가입일: 07/18/18
121 평판
안내서 1개를 작성함
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S4G4
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 999
