주요 콘텐츠로 건너뛰기
Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement
필요한 것
  1. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 1 단계, 이미지 1/3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 1 단계, 이미지 2/3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 1 단계, 이미지 3/3
    • To remove the plastic cover. You want to use the plastic opener and starting with corners.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use it carefully in order to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Carefully remove the cover as it can be very fragile
  2. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 2 단계, 이미지 1/3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 2 단계, 이미지 2/3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 2 단계, 이미지 3/3
    • Remove eight 10.5 mm Phillips #1 screws from the cover.
    • Insert a metal spurger at the corner to help loosen the cover.
    • There is still glue sticking the front cover and the back cover together.
    • Starting with corners, lift up the cover slowly and carefully.
    • Do not pull too hard when removing the cover. There are wires connecting between the battery and the circuit board.
  3. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 3 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 3 단계, 이미지 2/2
    • Identity the speaker cover, and remove four 4.5 mm Phillips #1 screws.
    • Lift up the cone. It should be removed very easily by hand.
  4. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 4 단계, 이미지 1/2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 4 단계, 이미지 2/2
    • Remove four 5.2mm Phillips #1 screws that are securing the circuit board.
    • Unplug the connecting wire from the circuit board. Carefully lift up the circuit board.
    • Same as step 3, remove four 4.5 mm Phillips #1 screws from the speaker cone.
결론
junyi yang
회원 가입일: 07/11/18
109 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S4G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 1,219
