주요 콘텐츠로 건너뛰기
Logitech Signature AI Edition M750 Battery Replacement
필요한 것
  1. Logitech Signature AI Edition M750 Battery Replacement, Turn off your mouse: 1 단계, 이미지 1개 중 1개
    • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
  2. Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 1개 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 2개 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery cover: 2 단계, 이미지 3개 중 3개
    • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
    • Remove the battery cover.
  3. Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 1개 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 2개 Logitech Signature AI Edition M750 Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 3개
    • Use your fingers to lift the end of the battery and slide it out of its recess.
    • During reassembly, slide the battery in negative (-) end first, as shown on the sticker in the recess.
결론
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
153,496 평판
안내서 1,024개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 92
