주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. When your Logitech Spotlight is not charging, the battery might be the problem.
    • When your Logitech Spotlight is not charging, the battery might be the problem.
  2. Disassemble lower parts of it.
    • Disassemble lower parts of it.
    • I could not find how to disassemble safely, so I just broke the plastic parts inside.
  3. Unscrew the screws beside the charging port.
    • Unscrew the screws beside the charging port.
  4. Disassemble the top cover.
    • Disassemble the top cover.
    • Watch out for the glue.
  5. Disassemble the back plate.
    • Disassemble the back plate.
    • Be careful for the plastic latch with double circles in the figure, and the glue.
  6. Unscrew the screws on the back.
    • Unscrew the screws on the back.
  7. You can slide the inside body upward from metal housing.
    • You can slide the inside body upward from metal housing.
    • On the inside body, unscrew 3 screws on the front.
    • Also watch out for the plastic latch with double circles in the figure.
  8. You can now access to the battery.
    • You can now access to the battery.
    • Replace the battery with a new one.
  9. The device is now working.
    • The device is now working.
결론
기기를 재조립하려면, 해당 지침을 역순으로 따라주십시오.
다른 2명이 해당 안내서를 완성하였습니다.
Sae Hee
회원 가입일: 2020년 05월 06일
1 평판
안내서 1개 작성함
what's the size of the battery?
Sky9dragon - 답글
3.9 mm thickness, 8 mm width, 36mm length.
Sae Hee - 답글
The actual removal of and the insertion of the replacement battery’s wire tips ( two ) into the tiny plastic insert is very tricky…
office - 답글
I bought the replacement battery from Aliexpress ( search: 90mAh 3.7V 350926 Lithium Polymer Li-Po li ion Rechargeable Battery)..https://www.aliexpress.com/item/33019400...
office - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 78
전체 시간: 972
