주요 콘텐츠로 건너뛰기
Logitech Spotlight Battery Replacement
필요한 것
  1. Logitech Spotlight Battery Replacement, Removing the back cover: 1 단계, 이미지 2개 중 1개 Logitech Spotlight Battery Replacement, Removing the back cover: 1 단계, 이미지 2개 중 2개
    • Removing the back cover :
    • The back cover is gluded on back middle and lower side. So it's much easier to rub in from top edge.
  2. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 2 단계, 이미지 3개 중 1개 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 2 단계, 이미지 3개 중 2개 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 2 단계, 이미지 3개 중 3개
    • Try to tick out the wire of the battery to get more space.
    • Cut out the yellow tape of battery.
    • Desoldering the two wires connecting the battery to the board. Carefully don't touch the the positive and negative terminals on the same time for security.
  3. Logitech Spotlight Battery Replacement, Pull out the battery: 3 단계, 이미지 1개 중 1개
    • Use pliers to clamp the board on the battery and pull the battery out. The battery is glued on the mainboard, and the battery is too long for back hole. So it's no easy to pull out.
  4. Logitech Spotlight Battery Replacement, Solder the new battery: 4 단계, 이미지 2개 중 1개 Logitech Spotlight Battery Replacement, Solder the new battery: 4 단계, 이미지 2개 중 2개
    • The original battery size is 3.9mm x 8mm x 36 mm. For ease of installation, I get a smaller battery with size 3.5mm x 8mm x 29 mm.
    • Put the new battery into the battery hole, and solder the new battery wires with the original wires. And use polyimide tape to cover the wiring point for safety .
  5. Logitech Spotlight Battery Replacement, Cover back the back cover: 5 단계, 이미지 1개 중 1개
    • Clear out the original clue on the two sides and put some clue on. Then Cover back the back cover.
결론
작성자
1다른 기여자 명과 함께
Leo Hsi
회원 가입일: 08/09/24
121 평판
안내서 1개를 작성함
1가이드 댓글
Potresti indicare tipo di batteria e dove comprarla? grazie
Sandro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 34
전체 시간: 523
