주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE Boom Bluetooth Adapter Replacement
필요한 것
  1. Logitech UE Boom Bluetooth Adapter Replacement, D-ring: 1 단계, 이미지 1개 중 1개
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    댓글 쓰기
  2. Logitech UE Boom Bluetooth Adapter Replacement: 2 단계, 이미지 2개 중 1개 Logitech UE Boom Bluetooth Adapter Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    댓글 쓰기
  3. Logitech UE Boom Bluetooth Adapter Replacement, Bluetooth Adapter: 3 단계, 이미지 1개 중 1개
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    댓글 쓰기
  4. Logitech UE Boom Bluetooth Adapter Replacement: 4 단계, 이미지 3개 중 1개 Logitech UE Boom Bluetooth Adapter Replacement: 4 단계, 이미지 3개 중 2개 Logitech UE Boom Bluetooth Adapter Replacement: 4 단계, 이미지 3개 중 3개
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    댓글 쓰기
  5. Logitech UE Boom Bluetooth Adapter Replacement: 5 단계, 이미지 2개 중 1개 Logitech UE Boom Bluetooth Adapter Replacement: 5 단계, 이미지 2개 중 2개
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    댓글 쓰기
  6. Logitech UE Boom Bluetooth Adapter Replacement: 6 단계, 이미지 3개 중 1개 Logitech UE Boom Bluetooth Adapter Replacement: 6 단계, 이미지 3개 중 2개 Logitech UE Boom Bluetooth Adapter Replacement: 6 단계, 이미지 3개 중 3개
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    댓글 쓰기
  7. Logitech UE Boom Bluetooth Adapter Replacement: 7 단계, 이미지 1개 중 1개
    • With the switch plate disconnected, remove it and your device should now look like this.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jose Cruz Arinaga
회원 가입일: 10/01/15
1,052 평판
안내서 3개를 작성함
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 회원
CPSU-MANESS-F15S4G1
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 33
지난 30일: 121
전체 시간: 12,381
