이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The D-ring is located on the bottom side of the speaker, furthest from the volume buttons; it is in between the auxiliary and charging ports. Removing this part will also remove the port covers on the device. It is important to note that continuing to tear apart the speaker past this step will void the warranty on your Logitech UE Boom.
Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
다른 5명이 해당 안내서를 완성하였습니다.
