주요 콘텐츠로 건너뛰기
Logitech UE Boom USB Port Replacement
필요한 것
  1. Logitech UE Boom USB Port Replacement, D-ring: 1 단계, 이미지 1/1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom USB Port Replacement: 2 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 2 단계, 이미지 2/2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom USB Port Replacement, Bluetooth Adapter: 3 단계, 이미지 1/1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    This part is not easy. The main risk is to broke the plastics clips.
    Optrolight - 답글
    Use a heat gun (or hair dryer on high) first around the edges before attempting to pry it open. There are six tabs: one directly in line with the charging port; one approx 3/4 inch to the left and right of that tab; one centered against the back of the volume control "panel", and one approx 3/4 inch to either side of that one. So when prying, try to insert your spudger in between those spacings in order to not push on the tabs directly.
    Lotus Flower - 답글
  4. Logitech UE Boom USB Port Replacement: 4 단계, 이미지 1/3 Logitech UE Boom USB Port Replacement: 4 단계, 이미지 2/3 Logitech UE Boom USB Port Replacement: 4 단계, 이미지 3/3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom USB Port Replacement: 5 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 5 단계, 이미지 2/2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom USB Port Replacement: 6 단계, 이미지 1/3 Logitech UE Boom USB Port Replacement: 6 단계, 이미지 2/3 Logitech UE Boom USB Port Replacement: 6 단계, 이미지 3/3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
    Great instructions here guys - just one comment from myself - underneath the plate there is glue holding it down as well as the solder joints. Be sure to heat it up slightly prior to lifting out otherwise the capacitors and other components get stuck in the glue.
    Jamie Horn - 답글
    bei mir sieht der blootooth-adapter anders aus. da muss ich nix löten, er ist klein und liegt nur in einer passenden mulde, aus der er herausgehoben und in die er wieder abgelegt werden kann. meine typbezeichnung ist S-00122.
    thomas propp - 답글
    Definitely start with the middle one, has 2 solder hinge points that took me a couple minutes to heat up, wiggle and finally lift up. One that side lifted, was much easier to go back to the edge hinge, heat up and just gently pull off.
    Michael Arvan - 답글
    It is importante to note that there are two large solder hinge points and for the midle to pin point. Easy to desoldering but not easy to soldering after battery replacement.
    Optrolight - 답글
  7. Logitech UE Boom USB Port Replacement: 7 단계, 이미지 1/1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. Logitech UE Boom USB Port Replacement, Lithium Battery: 8 단계, 이미지 1/1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. Logitech UE Boom USB Port Replacement: 9 단계, 이미지 1/1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
    Zuerst auf der Gegenseite zuerst den Deckel, dann die Hülle lösen. Erst am Ende die Seite mit dem Power Button.
    Hans Fuchs - 답글
    Translation: First loosen the cover on the opposite side, then the cover. Only at the end the page with the power button.
    Dan -
    A tips that could be help lot of us. i consider it what not easy to pry the sleeve off. But in fact there are many hole around the side that could be used to push through the holes, the plastic ring retainer.
    Optrolight - 답글
  10. Logitech UE Boom USB Port Replacement: 10 단계, 이미지 1/3 Logitech UE Boom USB Port Replacement: 10 단계, 이미지 2/3 Logitech UE Boom USB Port Replacement: 10 단계, 이미지 3/3
    • Peel off the sleeve.
  11. Logitech UE Boom USB Port Replacement: 11 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 11 단계, 이미지 2/2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. Logitech UE Boom USB Port Replacement: 12 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 12 단계, 이미지 2/2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. Logitech UE Boom USB Port Replacement: 13 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 13 단계, 이미지 2/2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. Logitech UE Boom USB Port Replacement: 14 단계, 이미지 1/1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. Logitech UE Boom USB Port Replacement: 15 단계, 이미지 1/1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. Logitech UE Boom USB Port Replacement: 16 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement: 16 단계, 이미지 2/2
    • Remove the battery by pulling it from the terminal as marked in the picture.
  17. Logitech UE Boom USB Port Replacement, USB Port: 17 단계, 이미지 1/2 Logitech UE Boom USB Port Replacement, USB Port: 17 단계, 이미지 2/2
    • Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
    Where can I find a replacement usb port for my speaker?
    Terry Velasquez - 답글
    ISO usb port for ue boom speaker?
    ASAP please
    Where can i find a USB replacing port please?
    julienvdb92 - 답글
    What is the wire diagram connection to USB port?
    joshuawt - 답글
    Where can I find the replacement USB port for my speaker ue 2
    Armando Fernandez - 답글
    Obviously they're not answering the main question where do you get the part. I sure went through a lot of trouble to stop there
    George Baxter - 답글
    iFixit can't offer every possible part need and the manufacture is the primary entity for parts.
    For many years you could depend on the makers to offer spares some even going back 25 years! Today its bad real bad! 5 years is about it some even less or they just don't offer repair options at all. True the cost of the device also plays a role here as well.
    The only option is to find a dead device to raid it for its parts when you can or hope someone picks up the challenge to create the part independently! That works with popular devices and parts like batteries.
    Dan -
결론
다른 9명이 해당 안내서를 완성하였습니다.
Sean Reilly
회원 가입일: 10/01/15
1,715 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 회원
CPSU-MANESS-F15S4G1
4 회원들
안내서 22개 작성하였습니다
댓글 12개
Hello,
does anyone know where to get new usb port, the logitech support didn´t really help.
cheers marius
kok0dora94 - 답글
Same question as above, where can i buy a replacement USB port?
Corbett Hix - 답글
i found 10 of them on ebay for 3-4 dollars
johnsonjohnsonalexalex - 답글
Hi there , can you give me a link to Ebay where to find this port, thanks
katiecrow -
can you send me a link on ebay where to find this replacement port , thanks
katiecrow -
I need to find the USB including the circuit board. My speaker needs that part replaced. Any idea where to get this?
Samuel Abraham - 답글
I would like to mail my speaker in for repairs what's the address? It needs a new port
Mike Stan - 답글
This is a one way street. Don’t bother even trying unless you have tremendous patience.
JASON MCKEE - 답글
Useless info about replacing the USB.
Alan Knowles - 답글
So if i call Logitech and tell them the problem would they replace my megaboom or fix it for me. Cause, mine fell with the charger connected and when it started flying (fell out the window about 3 ft high) it disconnected and broke the USB port on the speaker. Now i ended up throwing away my speakers charging cable but i still have the base it connects to.
Corwin Curlin Jr - 답글
Looking for link to purchase replacement USB charging plate/cover for UE Boom.
Thanks
Paul Gagnon - 답글
Hi - My UE Boom isn’t charging and isn’t turning on at all. Did anyone change the USD port and have it fix a problem like this?
Or do I need to change the battery too?
I would hate to take it apart, attempt to fix the USB and then find out that that wasn’t the issue. :)
Tiffany Ford - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 76
30일 전: 327
전체 시간: 31,853
