소개
This guide will show you how to replace the Bluetooth adapter in the Logitech UE Boombox.
필요한 것
Use a metal spudger to pry open the power button cover.
Once the power button cover is slightly opened, use your fingers to remove the power button cover.
Remove the fifteen 13.0mm Phillips #2 screws from the side of the device containing two speakers.
Separate the two halves by gently pulling them apart.
거의 끝나갑니다!
결론
