주요 콘텐츠로 건너뛰기
Logitech UE Boombox Speaker Grille Replacement
필요한 것
  1. Logitech UE Boombox Speaker Grille Replacement, Speaker Grille: 1 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement, Speaker Grille: 1 단계, 이미지 2/2
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Speaker Grille Replacement: 2 단계, 이미지 1/3 Logitech UE Boombox Speaker Grille Replacement: 2 단계, 이미지 2/3 Logitech UE Boombox Speaker Grille Replacement: 2 단계, 이미지 3/3
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Speaker Grille Replacement: 3 단계, 이미지 1/3 Logitech UE Boombox Speaker Grille Replacement: 3 단계, 이미지 2/3 Logitech UE Boombox Speaker Grille Replacement: 3 단계, 이미지 3/3
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Speaker Grille Replacement: 4 단계, 이미지 1/3 Logitech UE Boombox Speaker Grille Replacement: 4 단계, 이미지 2/3 Logitech UE Boombox Speaker Grille Replacement: 4 단계, 이미지 3/3
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Speaker Grille Replacement: 5 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 5 단계, 이미지 2/2
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Speaker Grille Replacement: 6 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 6 단계, 이미지 2/2
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Speaker Grille Replacement: 7 단계, 이미지 1/3 Logitech UE Boombox Speaker Grille Replacement: 7 단계, 이미지 2/3 Logitech UE Boombox Speaker Grille Replacement: 7 단계, 이미지 3/3
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Speaker Grille Replacement: 8 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 8 단계, 이미지 2/2
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Speaker Grille Replacement: 9 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 9 단계, 이미지 2/2
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Speaker Grille Replacement: 10 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 10 단계, 이미지 2/2
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Speaker Grille Replacement: 11 단계, 이미지 1/2 Logitech UE Boombox Speaker Grille Replacement: 11 단계, 이미지 2/2
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Speaker Grille Replacement: 12 단계, 이미지 1/1
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Speaker Grille Replacement: 13 단계, 이미지 1/3 Logitech UE Boombox Speaker Grille Replacement: 13 단계, 이미지 2/3 Logitech UE Boombox Speaker Grille Replacement: 13 단계, 이미지 3/3
    • Pull vertically on the speaker grille to remove it from the boombox.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
tyler hua
회원 가입일: 09/15/16
253 평판
안내서 1개 작성함
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Awesome guide thanks. Had to strip mine down as it stopped working, replugged it all and it’s good as new. Knowing how it’s down saves brute force and ignorance :)
matt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 935
