주요 콘텐츠로 건너뛰기
Logitech UE MegaBoom 3 Power Button Control Board Replacement
필요한 것
  1. Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: 1 단계, 이미지 2개 중 1개 Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: 1 단계, 이미지 2개 중 2개
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 2 단계, 이미지 3개 중 3개
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 3 단계, 이미지 3개 중 3개
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 4 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 4 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 5 단계, 이미지 3개 중 1개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 5 단계, 이미지 3개 중 2개 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 5 단계, 이미지 3개 중 3개
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Anthony Miles
회원 가입일: 09/04/23
1,021 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 71
전체 시간: 567
