주요 콘텐츠로 건너뛰기
Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
필요한 것
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 1 단계, 이미지 1/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 1 단계, 이미지 2/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 1 단계, 이미지 3/3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 2 단계, 이미지 1/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 2 단계, 이미지 2/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 2 단계, 이미지 3/3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 3 단계, 이미지 1/2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 3 단계, 이미지 2/2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 4 단계, 이미지 1/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 4 단계, 이미지 2/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 4 단계, 이미지 3/3
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 5 단계, 이미지 1/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 5 단계, 이미지 2/3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 5 단계, 이미지 3/3
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 6 단계, 이미지 1/2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 6 단계, 이미지 2/2
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Oscar Ambriz
회원 가입일: 09/27/17
958 평판
안내서 6개 작성하였습니다
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G2
4 회원들
안내서 14개 작성하였습니다
댓글 10개
How can I purchase this part being replaced thanks
Joseph Anderson - 답글
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - 답글
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - 답글
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 86
전체 시간: 11,296
