주요 콘텐츠로 건너뛰기
Logitech UE MegaBoom Battery Replacement
필요한 것
  1. Logitech UE MegaBoom Battery Replacement, Outer Mesh: 1 단계, 이미지 3개 중 1개 Logitech UE MegaBoom Battery Replacement, Outer Mesh: 1 단계, 이미지 3개 중 2개 Logitech UE MegaBoom Battery Replacement, Outer Mesh: 1 단계, 이미지 3개 중 3개
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Battery Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE MegaBoom Battery Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE MegaBoom Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Battery Replacement: 3 단계, 이미지 2개 중 1개 Logitech UE MegaBoom Battery Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Oscar Ambriz
회원 가입일: 09/27/17
977 평판
안내서 6개를 작성함
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G2
4 회원들
안내서 17개를 작성함
24가이드 댓글
There is a way to take it apart without all these steps and a complete tear down.
Brian Longhurst - 답글
How to ensure it’s waterproof upon reassembly?
mdeblasi - 답글
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
coryjohnson011 - 답글
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
sizz0p - 답글
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 138
지난 30일: 706
전체 시간: 63,089
