주요 콘텐츠로 건너뛰기
Logitech UE MegaBoom Outer Mesh Replacement
필요한 것
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 1 단계, 이미지 1/3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 1 단계, 이미지 2/3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 1 단계, 이미지 3/3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: 2 단계, 이미지 1/3 Logitech UE MegaBoom Outer Mesh Replacement: 2 단계, 이미지 2/3 Logitech UE MegaBoom Outer Mesh Replacement: 2 단계, 이미지 3/3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: 3 단계, 이미지 1/2 Logitech UE MegaBoom Outer Mesh Replacement: 3 단계, 이미지 2/2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Oscar Ambriz
회원 가입일: 09/27/17
958 평판
안내서 6개 작성하였습니다
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S9G2
4 회원들
안내서 14개 작성하였습니다
댓글 2개
You know where to buy a replacement mesh in custom colors
Jonathan Lang - 답글
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 21
전체 시간: 3,820
