주요 콘텐츠로 건너뛰기
Logitech UE Megaboom 4 Outer Case Replacement
필요한 것
  1. Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: 1 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: 1 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: 1 단계, 이미지 3개 중 3개
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Place the end of a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
  2. Logitech UE Megaboom 4 Outer Case Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the bottom end of the speaker off and place it aside.
    • Once the glued seal is broken you will be able to pull it off with your hands.
  3. Logitech UE Megaboom 4 Outer Case Replacement: 3 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Outer Case Replacement: 3 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Outer Case Replacement: 3 단계, 이미지 3개 중 3개
    • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
    • The inside components will begin to slide out of the top from the mesh casing.
  4. Logitech UE Megaboom 4 Outer Case Replacement: 4 단계, 이미지 1개 중 1개
    • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
2다른 기여자 명과 함께
Konner Buchal
회원 가입일: 02/03/25
470 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 97
