주요 콘텐츠로 건너뛰기
Logitech UE Megaboom 4 Power Button Board Replacement
필요한 것
  1. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: 1 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: 1 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: 1 단계, 이미지 3개 중 3개
    • Place the end of a metal spudger in the seam between the top cover and outer case of the speaker. Work your way around the seam of the cover to loosen it.
    • This will take force as it is glued down with the waterproofing sealant.
    • Be careful when using the metal spudger. It is sharp and can cause damage to your device and yourself.
    • Separate the top cover of the speaker from the case.
  2. Logitech UE Megaboom 4 Power Button Board Replacement: 2 단계, 이미지 2개 중 1개 Logitech UE Megaboom 4 Power Button Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove four screws from the underside of the top cover of the speaker.
    • Remove the black bracket covering the button board.
  3. Logitech UE Megaboom 4 Power Button Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the circuit board from the cap.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eden Norris
회원 가입일: 02/10/25
216 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 132
