주요 콘텐츠로 건너뛰기
Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement
필요한 것
  1. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the USB Wireless Receiver: 1 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the USB Wireless Receiver: 1 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the USB Wireless Receiver: 1 단계, 이미지 3/3
    • Wash your hands before replacing the battery to prevent debris getting into the mouse and damaging its internal components.
    • Orient the mouse so you are viewing its base.
    • Using your fingers, gently remove the USB wireless receiver by sliding it towards you.
    • USB removal will result in the power switch to be in its ON position.
    • Place the USB to the side for reassembly.
    • With your fingertip, engage the power switch to its OFF position to ensure the mouse is not powered.
  2. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Mouse Pads: 2 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Mouse Pads: 2 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Mouse Pads: 2 단계, 이미지 3/3
    • Locate the four mouse pads.
    • Use the rectangular end of the metal spudger to get underneath each mouse pad, pry them up, and peel them off.
    • Set the peeled mouse pads to the side sticky-side up to maintain its stickiness.
  3. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Unscrewing the Mouse Housing Screws: 3 단계, 이미지 1/1
    • Locate the four #0 Phillips screws where the mouse pads previously were.
    • Unscrew the four #0 Phillips screws with the Phillips #0 screwdriver.
    • Set the screws to the side for reassembly.
  4. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Separating the Mouse Housing: 4 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Separating the Mouse Housing: 4 단계, 이미지 2/2
    • Once the housing screws are fully removed, slowly (and carefully) separate the top and bottom halves of the housing.
    • Rapid separation of the housing halves may result in damaging the power cables (red and black wires) and molex (white plug).
  5. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Detaching the Top Mouse Housing: 5 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Detaching the Top Mouse Housing: 5 단계, 이미지 2/2
    • Gently set the mouse halves down on a flat surface.
    • Secure the base half with one hand.
    • With thumb and forefinger, grab the end of the molex and pull it away from you until the molex is unplugged.
    • Set the top mold half to the side for reassembly.
  6. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Scroll Wheel: 6 단계, 이미지 1/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Scroll Wheel: 6 단계, 이미지 2/3 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing the Scroll Wheel: 6 단계, 이미지 3/3
    • Locate the one, scroll wheel, #0 Phillips screw near the very front edge of the mouse.
    • Turn the mouse 90 degrees clockwise.
    • While supporting the rear of the mouse base, unscrew the #0 Phillips scroll wheel screw.
    • Set the screw to the side for reassembly.
    • Once the scroll wheel screw is fully removed, manually extract the scroll wheel and spring assembly.
    • Set the remains of the base of the mouse to the side.
  7. Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing and Replacing the Scroll Wheel Spring: 7 단계, 이미지 1/2 Logitech V220 - Cordless Optical Mouse Scroll Wheel Replacement, Removing and Replacing the Scroll Wheel Spring: 7 단계, 이미지 2/2
    • Locate the scroll wheel spring.
    • Use the tweezers to gently remove the spring by slowly tugging the spring away from the scroll wheel assembly.
    • Set the spring aside for proper disposal.
    • Grab a new spring with the tweezers.
    • Place the new spring on the peg extrusion of the assembly.
    • Now you have a new scroll wheel spring!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler Price
회원 가입일: 04/07/14
1,038 평판
안내서 6개 작성하였습니다
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 회원
CPSU-FORTE-S14S6G2
5 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 1,350
