주요 콘텐츠로 건너뛰기
Logitech VX Nano Wireless Mouse Scroll Wheel Replacement
필요한 것
  1. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement, Remove batteries and Nano Receiver: 1 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement, Remove batteries and Nano Receiver: 1 단계, 이미지 2/2
    • Pull down on the battery release tab to remove the battery cover.
    • Remove battery cover.
  2. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 2 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 2 단계, 이미지 2/2
    • Pull the battery release tab away from the mouse until the two AA batteries come out.
  3. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 1/1
    • If the Nano Receiver is still in the mouse, push the bright orange button to remove it. It should pop right out.
  4. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement, Open the mouse: 4 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the two 6 mm-long screws at the bottom of the battery compartment.
    • To more easily access the two screws, you could hold the plastic battery tab out of the way of your screwdriver.
  5. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 2/2
    • Removing the mouse skates will damage them. During reassembly, you will need to install a new set of skates.
    • Insert an opening pick underneath the corner of one of the adhesive skates.
    • As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
    • Continue to push the opening pick between the adhesive pad and the mouse case, slowly working the adhesive away from the case.
    • Repeat this same process for the two other skates.
    • During reassembly, remove any old adhesive residue before applying new mouse skates.
    It is yet possible to remove the pads without damaging them (but not always easy !) If you manage to remove the pads, which glue shall be used to glue them back ?
    Volny - 답글
  6. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the three 6 mm-long screws from the backside of the mouse.
    • The top shell and bottom case are no longer connected. Keep the mouse level so the top shell doesn't fall off.
  7. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 7 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 7 단계, 이미지 2/2
    • Lift the top shell straight up to separate the top plastic shell from the bottom case.
    • Remove the top shell.
  8. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement, Remove the scroll wheel: 8 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement, Remove the scroll wheel: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to carefully pry one side of the scroll wheel out of its clear plastic housing.
    • Use a set of tweezers to grasp either side of the scroll wheel near the axle. Use one side of the tweezers to keep the scroll wheel from popping back into the clear plastic housing on the side you already disconnected.
    • At the same time, use the other side of the tweezers to pull the opposite side of the scroll wheel loose from the clear plastic housing.
    • This may take multiple tries. Don't lose hope! Use the tweezers to hold the clear plastic away from the scroll wheel as you pull up on it in the next step.
  9. Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 9 단계, 이미지 1/2 Logitech VX Nano Wireless Mouse Scroll Wheel Replacement: 9 단계, 이미지 2/2
    • Pull the scroll wheel up and away from the clear plastic housing and the spring holding it in place.
    • These plastic pieces are brittle! Too much bending force can break the scroll wheel housing.
    • Before reassembly, check that the replacement scroll wheel easily switches between smooth and indexed scrolling.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
113,871 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,139개 작성하였습니다
댓글 2개
Thanks for the instruction!
Although I think it is impossible to remove the skates (pads, feet, whatever you call them) without damaging them.
But the replacement is still relatively easy to find on Ali or ebay.
Anton Leushin - 답글
You’re totally right! I’ll add this clarification to the step. Thanks!
Carsten Frauenheim -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 54
전체 시간: 2,469
