주요 콘텐츠로 건너뛰기
Logitech Webcam Pro 9000 Microphone Replacement
필요한 것
  1. Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: 1 단계, 이미지 1/2 Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: 1 단계, 이미지 2/2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Microphone Replacement: 2 단계, 이미지 1/2 Logitech Webcam Pro 9000 Microphone Replacement: 2 단계, 이미지 2/2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: 3 단계, 이미지 1/2 Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: 3 단계, 이미지 2/2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  4. Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 4 단계, 이미지 1/3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 4 단계, 이미지 2/3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 4 단계, 이미지 3/3
    • Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
    • Use the wedge to separate the two pieces.
    • It might take more force than expected.
  5. Logitech Webcam Pro 9000 Microphone Replacement: 5 단계, 이미지 1/3 Logitech Webcam Pro 9000 Microphone Replacement: 5 단계, 이미지 2/3 Logitech Webcam Pro 9000 Microphone Replacement: 5 단계, 이미지 3/3
    • Twist the rubber casing and remove it from the plastic cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
nieko
회원 가입일: 04/18/13
63 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 2,034
