주요 콘텐츠로 건너뛰기
Logitech Webcam Pro 9000 Motherboard Replacement
필요한 것
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 1 단계, 이미지 1/2 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 1 단계, 이미지 2/2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Motherboard Replacement: 2 단계, 이미지 1/2 Logitech Webcam Pro 9000 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 1/3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 2/3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 3/3
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 4 단계, 이미지 1/2 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 4 단계, 이미지 2/2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 5 단계, 이미지 1/2 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 5 단계, 이미지 2/2
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  6. Logitech Webcam Pro 9000 Motherboard Replacement: 6 단계, 이미지 1/2 Logitech Webcam Pro 9000 Motherboard Replacement: 6 단계, 이미지 2/2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: 7 단계, 이미지 1/1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  8. Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 1/3 Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 2/3 Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cory Davis
회원 가입일: 04/14/13
236 평판
안내서 4개 작성하였습니다
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 2,067
