주요 콘텐츠로 건너뛰기
Logitech Webcam Pro 9000 Snapshot Button Replacement
필요한 것
  1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: 1 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Snapshot Button Replacement: 2 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Snapshot Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 3 단계, 이미지 3개 중 1개 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 3 단계, 이미지 3개 중 2개 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 3 단계, 이미지 3개 중 3개
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Cory Davis
회원 가입일: 04/14/13
236 평판
안내서 4개를 작성함
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개를 작성함
3가이드 댓글
Power button? Does this actually turn the camera on and off? When I push it, it seems to just pause the screen for a moment. I thought maybe it was taking still shots, but I cant seem to find a folder with any in it. I've checked all Logitech's default folder directories. (Trying to figure out what this button does, or can actually be used for.) If you want to turn a webcam off, you usually just unplug them.
Edit: Manual says its a snapshot button, but I'd love for this to start/stop OR pause recording. Hm.....
Harrison - 답글
I've tried to properly update this to make it more accurate, but I'm unsure how the process works. Maybe I submitted it for review? I'm not sure, but my changes have not taken effect, yet.
Harrison - 답글
They were indeed submitted for approval, and have been approved! =)
Sam Goldheart -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 2,322
