주요 콘텐츠로 건너뛰기
Logitech Wireless K360 Printed Circuit Board (PCB) Replacement
필요한 것
  1. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the keyboard face down.
  2. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 2 단계, 이미지 1개 중 1개
    • With your thumbs on both sides of the battery tab, push upwards.
    • You should feel it disconnect.
    • Remove the cover exposing the batteries.
  3. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the old batteries.
    • Make sure the keyboard turns on and works.
    • Double check that the cover is back on correctly; you don't want it coming off and have the batteries fall out!
  4. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 4 단계, 이미지 3개 중 1개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 4 단계, 이미지 3개 중 2개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 4 단계, 이미지 3개 중 3개
    • Remove the keyboard cover.
    • Remove the screws using a Phillips #0 screwdriver.
    • There are a total of eight 8mm screws and twelve 6mm screws.
  5. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 5 단계, 이미지 2개 중 1개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the top half of the keyboard carefully.
    • If there are issues removing the top half of the keyboard, you can try using something thin to get into the crevices.
  6. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 6 단계, 이미지 3개 중 1개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 6 단계, 이미지 3개 중 2개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 6 단계, 이미지 3개 중 3개
    • Unscrew the two 2.0 mm silver screws using a Phillips #0 screwdriver.
  7. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 7 단계, 이미지 3개 중 1개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 7 단계, 이미지 3개 중 2개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 7 단계, 이미지 3개 중 3개
    • Unscrew the two 2.0 mm silver screws on either side of the printed circuit board (PCB) using a Phillips #0 screwdriver.
  8. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 8 단계, 이미지 3개 중 1개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 8 단계, 이미지 3개 중 2개 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the entire printed circuit board (PCB) out of the panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Othon Sanchez
회원 가입일: 02/20/25
321 평판
안내서 2개를 작성함
CSU Los Angeles, Team 7-3, Kershman Spring 2025 CSU Los Angeles, Team 7-3, Kershman Spring 2025 회원
CSULA-KERSHMAN-S25S7G3
5 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 36
전체 시간: 232
