주요 콘텐츠로 건너뛰기
Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement
필요한 것
  1. Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Model Z515: 1 단계, 이미지 1개 중 1개
    • Logitech Z515 Bluetooth Speaker (c. 2010). Specs and review…
    • CNET.com
  2. Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove Battery Compartment Cover: 2 단계, 이미지 3개 중 1개 Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove Battery Compartment Cover: 2 단계, 이미지 3개 중 2개 Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove Battery Compartment Cover: 2 단계, 이미지 3개 중 3개
    • Using a TORX T10H bit, under the flip cover/stand, remove the four screws holding the battery cover in place.
  3. Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 1개 Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 2개 Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Remove the battery: 3 단계, 이미지 3개 중 3개
    • The battery can be easily removed by using your fingernail or a small flathead to pry the connector free. It is held in place by tension on both sides. Once detached, flip the speaker over and the battery will fall out.
  4. Logitech Z515 Bluetooth Speaker Rechargeable Battery Replacement, Install new battery.: 4 단계, 이미지 1개 중 1개
    • A replacement battery can be purchased from Amazon at the link below, or search for "NiMH 3.6v 1800mAh rechargeable battery" Amazon.com
    • Reinstall battery and cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Vincent
회원 가입일: 05/20/13
199 평판
안내서 1개를 작성함
1가이드 댓글
My speaker is very old, and neglected, but I still had the power supply for it.
My battery cover only had two screws. The battery replacement was as described in the tutorial.
Glad I had this guide before I started removing the wrong screws!
Logitech is very good quality.
Thanks.
TIM O'LEARY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 50
전체 시간: 1,266
