주요 콘텐츠로 건너뛰기
Longboard or Skateboard Truck Maintenance
필요한 것
  1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: 1 단계, 이미지 1/2 Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: 1 단계, 이미지 2/2
    • Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
  2. Longboard or Skateboard Truck Maintenance: 2 단계, 이미지 1/1
    • Use your fingers to fully loosen and remove the nuts from the bolts.
    • Nuts are small and easy to lose track of.
  3. Longboard or Skateboard Truck Maintenance: 3 단계, 이미지 1/3 Longboard or Skateboard Truck Maintenance: 3 단계, 이미지 2/3 Longboard or Skateboard Truck Maintenance: 3 단계, 이미지 3/3
    • Use your hands to remove the trucks from the deck.
    • Make sure the kingpin is facing outward, If the kingpin is not properly reinstalled, the trucks will fail to perform properly.
  4. Longboard or Skateboard Truck Maintenance: 4 단계, 이미지 1/1
    • Remove the truck raiser if applicable.
  5. Longboard or Skateboard Truck Maintenance: 5 단계, 이미지 1/2 Longboard or Skateboard Truck Maintenance: 5 단계, 이미지 2/2
    • Remove the bolts from the factory drilled holes on the deck.
    • Note that the bolts are small and easy to lose track of.
  6. Longboard or Skateboard Truck Maintenance: 6 단계, 이미지 1/1
    • Clean the deck with a moist cloth or cleaning solution.
  7. Longboard or Skateboard Truck Maintenance: 7 단계, 이미지 1/1
    • Clean the trucks with a moist cloth or cleaning solution.
  8. Longboard or Skateboard Truck Maintenance: 8 단계, 이미지 1/2 Longboard or Skateboard Truck Maintenance: 8 단계, 이미지 2/2
    • Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
  9. Longboard or Skateboard Truck Maintenance: 9 단계, 이미지 1/1
    • Repeat steps 1-7 with the second truck.
  10. Longboard or Skateboard Truck Maintenance: 10 단계, 이미지 1/1
    • After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
    • Over tightening the bolts can cause them to strip.
    • Failure to tighten the bolts and nuts properly may lead to improper performance.
  11. Longboard or Skateboard Truck Maintenance: 11 단계, 이미지 1/2 Longboard or Skateboard Truck Maintenance: 11 단계, 이미지 2/2
    • After re-installing the trucks, check and confirm the kingpin is facing outward.
    • Failure to do this will cause the longboard's functions to be inverted, which may lead to personal injury.
결론
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic Turano
회원 가입일: 09/21/15
122 평판
안내서 1개 작성함
Colorado Springs, Team 6-2, Mcmichael Fall 2015 Colorado Springs, Team 6-2, Mcmichael Fall 2015 회원
UCCS-MCMICHAEL-F15S6G2
4 회원들
안내서 1개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 36
전체 시간: 7,196
