주요 콘텐츠로 건너뛰기
Lorex A-MPX IR Bullet Camera Disassembly
필요한 것
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: 1 단계, 이미지 1/2 Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: 1 단계, 이미지 2/2
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: 2 단계, 이미지 1/2 Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: 2 단계, 이미지 2/2
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 3 단계, 이미지 1/3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 3 단계, 이미지 2/3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: 3 단계, 이미지 3/3
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 4 단계, 이미지 1/3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 4 단계, 이미지 2/3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: 4 단계, 이미지 3/3
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: 5 단계, 이미지 1/1
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
결론
Hans
회원 가입일: 10/20/14
1,920 평판
안내서 6개 작성하였습니다
Mero IT Services Mero IT Services 회원
Business
1 회원
안내서 6개 작성하였습니다
댓글 3개
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - 답글
Can you do a disassembly video on Lorex C861MB camera ?
Mark Curry - 답글
How much is this camera
Michael Teeter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 40
전체 시간: 2,536
