소개
The lens of the Lorex MC 6950 is to be replaced. This will require taking the camera apart and removing the circuit board from it's LED containment. To do this, a metal spudger and a #J0 screwdriver will be needed.
필요한 것
To remove the circuit board, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
Once the camera is removed, remove the wires from the outer containment shell.
Be careful. The metal spudger could damage the camera if not handled with care.
다른 한 분이 해당 안내서를 완성하였습니다.
