소개
The 1.5v DC motor of the Lorex MC 6950 is to be replaced. This will require taking the camera apart and removing the circuit board from it's LED containment. The motor can be removed directly from the circuit board. To do this, a metal spudger, soldering iron, and a #J0 screwdriver will be needed.
필요한 것
To remove the motor, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
다른 한 분이 해당 안내서를 완성하였습니다.
