주요 콘텐츠로 건너뛰기
Lower Unit Service (Johnson 40 Motor)
필요한 것
  1. Lower Unit Service (Johnson 40 Motor), Propellor Replacement: 1 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor), Propellor Replacement: 1 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor), Propellor Replacement: 1 단계, 이미지 3개 중 3개
    • Remove the cotter pin that is stuck through the propeller shaft using a pair of pliers.
    • You can reinstall the old cotter pin, but it will be easier to install a new one.
  2. Lower Unit Service (Johnson 40 Motor): 2 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 2 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 2 단계, 이미지 3개 중 3개
    • Using the special wrench, loosen and remove the castle nut.
    • Behind the castle nut will be a washer, set the washer on top of the castle nut to help remember the order in which everything comes off.
    • When tightening the castle nut, make sure not to block the hole for the cotter pin
  3. Lower Unit Service (Johnson 40 Motor): 3 단계, 이미지 1개 중 1개
    • Remove the propeller.
    • There is another washer behind the propeller that may come off with the propeller, check for this before installing new propeller
  4. Lower Unit Service (Johnson 40 Motor), Anode Replacement: 4 단계, 이미지 1개 중 1개
    • If the washer behind the propeller did not come off with the propeller, remove it and set it aside with the propeller, other washer, and castle nut.
  5. Lower Unit Service (Johnson 40 Motor): 5 단계, 이미지 2개 중 1개 Lower Unit Service (Johnson 40 Motor): 5 단계, 이미지 2개 중 2개
    • Remove the two screws on either side holding the anode in place using a 5/16 nut driver.
  6. Lower Unit Service (Johnson 40 Motor): 6 단계, 이미지 1개 중 1개
    • Pull the anode out
    • Reverse the previous steps to reinstall
  7. Lower Unit Service (Johnson 40 Motor), Water Pump Replacement: 7 단계, 이미지 2개 중 1개 Lower Unit Service (Johnson 40 Motor), Water Pump Replacement: 7 단계, 이미지 2개 중 2개
    • Remove upper cowl by turning the black levers on the front and rear of the cowl
  8. Lower Unit Service (Johnson 40 Motor): 8 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 8 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 8 단계, 이미지 3개 중 3개
    • Remove the lower cowl by removing the one 3/8 in bolt from the front
    • the two 3/8 in bolts from the rear of the lower cowl
    • One bolt is under the rear latch
    • the 3/8 in bolt under the bottom of the lower cowl. This is most easily done using a universal-joint socket.
  9. Lower Unit Service (Johnson 40 Motor): 9 단계, 이미지 1개 중 1개
    • Trim the engine all the way up and pull the two halves away from the engine and downward, removing the rubber holders for the battery connection and control cables
  10. Lower Unit Service (Johnson 40 Motor): 10 단계, 이미지 2개 중 1개 Lower Unit Service (Johnson 40 Motor): 10 단계, 이미지 2개 중 2개
    • Remove the 3/8 in screw connecting the vertical shift linkage going into the lower unit to the horizontal shift linkage in the upper unit. This Is located directly below the block on the port side of the engine.
    • this is a special tapered bolt
  11. Lower Unit Service (Johnson 40 Motor): 11 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 11 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 11 단계, 이미지 3개 중 3개
    • Remove the four 9/16 in bolts connecting the lower unit to the upper unit. This will need to be done with a regular wrench.
    • These bolts have washers
  12. Lower Unit Service (Johnson 40 Motor): 12 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 12 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 12 단계, 이미지 3개 중 3개
    • Remove the one 5/8 in bolt holding the lower unit to the upper unit. This is located directly above the propeller. As you do this the lower unit will begin to pull away from the upper unit.
    • Make sure to align the shift linkage with the bracket that holds it before fully tightening the bolt
    • the lower unit may begin to slip out after this bolt is removed.
  13. Lower Unit Service (Johnson 40 Motor): 13 단계, 이미지 1개 중 1개
    • Remove the lower unit from the upper unit by gently pulling the lower unit straight away from upper unit, taking care not to bend the shaft or shift linkage.
    • If the lower unit seems stuck, gently wiggle it until it comes out freely
    • 8. Place the lower unit on a table or put it up in a vice if one is available. This needs to be a clutter free workspace to ensure that the small parts in the water pump can be found if dropped
    • If you do put it in a vice, do not over tighten and use soft jaws if possible or a rag you can’t use soft jaws to protect the lower unit from being scratched or dented.
  14. Lower Unit Service (Johnson 40 Motor): 15 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 15 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 15 단계, 이미지 3개 중 3개
    • Remove the four 7/16 in bolts holding the water pump to the lower unit
  15. Lower Unit Service (Johnson 40 Motor): 16 단계, 이미지 1개 중 1개
    • Remove the outer water pump housing by sliding it up the shaft. This should expose the inner housing.
  16. Lower Unit Service (Johnson 40 Motor): 17 단계, 이미지 3개 중 1개 Lower Unit Service (Johnson 40 Motor): 17 단계, 이미지 3개 중 2개 Lower Unit Service (Johnson 40 Motor): 17 단계, 이미지 3개 중 3개
    • Remove the inner housing. The impeller should be stuck tightly inside the inner housing and will come off with it.
    • The impeller has a key that holds it to the shaft that will fall out, be careful not to lose it.
  17. Lower Unit Service (Johnson 40 Motor): 18 단계, 이미지 2개 중 1개 Lower Unit Service (Johnson 40 Motor): 18 단계, 이미지 2개 중 2개
    • Remove the old impeller from the housing and install the new one.
    • Make sure the side of the impeller with the grove for the key will be facing downward when installed.
  18. Lower Unit Service (Johnson 40 Motor): 19 단계, 이미지 2개 중 1개 Lower Unit Service (Johnson 40 Motor): 19 단계, 이미지 2개 중 2개
    • To replace the impeller and inner housing, first put the key into the notch on the shaft and slide the impeller and inner housing down the shaft lining up the key with the notch on the impeller.
    • It may be beneficial to turn the lower unit on it’s side so that gravity will hold the key in place.
  19. Lower Unit Service (Johnson 40 Motor): 20 단계, 이미지 1개 중 1개
    • Slide the housing down the shaft and make sure the seal for the outer housing is sitting in the grove on the underside of the outer housing.
    • If the outer housing does not want to go over the inner housing, slowly rotate the shaft while applying gentle downward pressure to the upper housing until it slides into place.
    • To finish installation, follow the removal steps in reverse starting at step 9
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Elijah Durkee
회원 가입일: 11/12/21
388 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 145
전체 시간: 4,304
