주요 콘텐츠로 건너뛰기
Lubricate General Electric Telephone 2-9710A Power Dial
필요한 것
  1. Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: 1 단계, 이미지 1/2 Lubricate General Electric Telephone 2-9710A Power Dial, Phone Cord: 1 단계, 이미지 2/2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Power Dial: 2 단계, 이미지 1/3 Lubricate General Electric Telephone 2-9710A Power Dial: 2 단계, 이미지 2/3 Lubricate General Electric Telephone 2-9710A Power Dial: 2 단계, 이미지 3/3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: 3 단계, 이미지 1/2 Lubricate General Electric Telephone 2-9710A Power Dial, 9V Base Battery: 3 단계, 이미지 2/2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: 4 단계, 이미지 1/2 Lubricate General Electric Telephone 2-9710A Power Dial, Remove Volume Dial: 4 단계, 이미지 2/2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Power Dial, Remove Screws on the Back: 5 단계, 이미지 1/1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: 6 단계, 이미지 1/2 Lubricate General Electric Telephone 2-9710A Power Dial, Pry the Back Off: 6 단계, 이미지 2/2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Power Dial, Lubricate General Electric Telephone 2-9710A Power Dial: 7 단계, 이미지 1/1
    • Inside the base shell on the circuit board, lubricate the power switch.
    • Make sure the lubricant does not get on the circuit board. This can damage the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Norberto Sanchez
회원 가입일: 09/26/12
70 평판
안내서 5개 작성하였습니다
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 회원
CPSU-FORTE-F12S16G59
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 880
