주요 콘텐츠로 건너뛰기
Lumen Projector Bulb Replacement
필요한 것
  1. Lumen Projector Bulb Replacement, Unplug projector: 1 단계, 이미지 1/1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Lumen Projector Bulb Replacement: 2 단계, 이미지 1/1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Lumen Projector Bulb Replacement: 3 단계, 이미지 1/1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Lumen Projector Bulb Replacement: 4 단계, 이미지 1/1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Lumen Projector Bulb Replacement: 5 단계, 이미지 1/1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Lumen Projector Bulb Replacement: 6 단계, 이미지 1/1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Lumen Projector Bulb Replacement: 7 단계, 이미지 1/1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Lumen Projector Bulb Replacement: 8 단계, 이미지 1/1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Lumen Projector Bulb Replacement: 9 단계, 이미지 1/1
    • Dispose of the bulb by sending it to a recycling center.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Desiree Benitez
회원 가입일: 01/21/17
128 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 20개 작성하였습니다
댓글 한 개
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 801
