주요 콘텐츠로 건너뛰기
Lytro Camera First Generation Repair
필요한 것
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: 1 단계, 이미지 1/1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: 2 단계, 이미지 1/1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: 3 단계, 이미지 1/1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: 4 단계, 이미지 1/1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: 5 단계, 이미지 1/1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: 6 단계, 이미지 1/1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: 8 단계, 이미지 1/1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: 9 단계, 이미지 1/1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: 10 단계, 이미지 1/1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
결론
Jeremiah Killam-Hull
회원 가입일: 02/08/17
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 18
전체 시간: 487
