주요 콘텐츠로 건너뛰기
M3D Micro Motor Replacement
필요한 것
  1. M3D Micro Motor Replacement, M3D Micro Frame Removal: 1 단계, 이미지 1/1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Motor Replacement: 2 단계, 이미지 1/3 M3D Micro Motor Replacement: 2 단계, 이미지 2/3 M3D Micro Motor Replacement: 2 단계, 이미지 3/3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
    I could get it loose on one side. The other is firmly stuck. It does let me flip the head up to the side, but it won’t come loose without significant violence.
    Also, to the the first one loose, I have to pull the Y-rods so hard that they bend. Not plastic deformation, they are not ruined (I think) but the amount of force disturbs me.
    Ragnemalm - 답글
  3. M3D Micro Motor Replacement: 3 단계, 이미지 1/2 M3D Micro Motor Replacement: 3 단계, 이미지 2/2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
    This doesn’t work at all on my M3D. I had to force in a tool, a kitchen knife, to crack it open in each corner. THEN I can lift it up. (But I still can’t lift it off since I can’t remove the printer head. More force needed there.)
    Reassembly is harder, because you have six rods that must get into separate holes more or less simultaneously, and I guess those small metal rings on the top have a purpose too.
    Ragnemalm - 답글
  4. M3D Micro Motor Replacement, Motor: 4 단계, 이미지 1/1
    • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
    You forgot one step: How to remove the base!
    Ragnemalm - 답글
  5. M3D Micro Motor Replacement: 5 단계, 이미지 1/2 M3D Micro Motor Replacement: 5 단계, 이미지 2/2
    • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
  6. M3D Micro Motor Replacement: 6 단계, 이미지 1/2 M3D Micro Motor Replacement: 6 단계, 이미지 2/2
    • Once disconnected you will proceed to lift the motor using pliers.
  7. M3D Micro Motor Replacement: 7 단계, 이미지 1/2 M3D Micro Motor Replacement: 7 단계, 이미지 2/2
    • Now, remove the motor.
결론
Miguel Pina
회원 가입일: 10/17/17
101 평판
안내서 1개 작성함
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 회원
USFT-NANCE-F17S3G2
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,586
