주요 콘텐츠로 건너뛰기
M3t Kiosk Preventative maintenance
필요한 것
  1. M3t Kiosk  Preventative maintenance, Handle and Lock: 1 단계, 이미지 1/1
    • Make sure the door lock and handle are in good working order and not bent or loose
  2. M3t Kiosk  Preventative maintenance, Opt cords: 2 단계, 이미지 1/2 M3t Kiosk  Preventative maintenance, Opt cords: 2 단계, 이미지 2/2
    • Check the opt cords to make sure they aren’t broken or crimped
  3. M3t Kiosk  Preventative maintenance, Opt Lights: 3 단계, 이미지 1/1
    • Make sure all the opt box lights that are supposed to be on are on.
  4. M3t Kiosk  Preventative maintenance, Dispenser Belts: 4 단계, 이미지 1/2 M3t Kiosk  Preventative maintenance, Dispenser Belts: 4 단계, 이미지 2/2
    • Clean belts on top and on the back of the dispenser.
  5. M3t Kiosk  Preventative maintenance, Test Dispense: 5 단계, 이미지 1/3 M3t Kiosk  Preventative maintenance, Test Dispense: 5 단계, 이미지 2/3 M3t Kiosk  Preventative maintenance, Test Dispense: 5 단계, 이미지 3/3
    • Test dispense the coin hoppers and the cash dispenser
  6. M3t Kiosk  Preventative maintenance, Test Dispense (continued): 6 단계, 이미지 1/2 M3t Kiosk  Preventative maintenance, Test Dispense (continued): 6 단계, 이미지 2/2
    • (Continued)
  7. M3t Kiosk  Preventative maintenance: 7 단계, 이미지 1/1
    • Check the coin hoppers to make sure nothing is in it other than coins (like rubber bands or something that was dropped in it)
  8. M3t Kiosk  Preventative maintenance, Fans: 8 단계, 이미지 1/2 M3t Kiosk  Preventative maintenance, Fans: 8 단계, 이미지 2/2
    • Clean any dust off of the fans
  9. M3t Kiosk  Preventative maintenance, Printer: 9 단계, 이미지 1/1
    • Check the printer for paper and put in more if it's needed
  10. M3t Kiosk  Preventative maintenance: 10 단계, 이미지 1/2 M3t Kiosk  Preventative maintenance: 10 단계, 이미지 2/2
    • Open and blow out the printer to remove any loose paper
  11. M3t Kiosk  Preventative maintenance, Clean Bill Validator: 11 단계, 이미지 1/1
    • Run a cleaning strip through the BV
  12. M3t Kiosk  Preventative maintenance, Bill Validator board: 12 단계, 이미지 1/1
    • Check for coins on the BV board.
  13. M3t Kiosk  Preventative maintenance, Bill Validator protector: 13 단계, 이미지 1/1
    • Put a board protector on if it’s missing and you have one available
  14. M3t Kiosk  Preventative maintenance, Screen cleaning: 14 단계, 이미지 1/1
    • Clean the touch screen
  15. M3t Kiosk  Preventative maintenance, Door lights: 15 단계, 이미지 1/1
    • Check to see if the door lights are on and working
결론
다른 2명이 해당 안내서를 완성하였습니다.
Timothy Morse
회원 가입일: 12/30/15
1,198 평판
안내서 6개 작성하였습니다
The Curo Group The Curo Group 회원
Community
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 267
