주요 콘텐츠로 건너뛰기
M3t Kiosk UPC APC Troubleshooting
필요한 것
  1. M3t Kiosk UPC APC Troubleshooting, UPC APC: 1 단계, 이미지 1/3 M3t Kiosk UPC APC Troubleshooting, UPC APC: 1 단계, 이미지 2/3 M3t Kiosk UPC APC Troubleshooting, UPC APC: 1 단계, 이미지 3/3
    • The UPC is located at the bottom right of the machine. Before removing it you should shut down the kiosk and power down the machine via the two switches on the top left of the machine.
  2. M3t Kiosk UPC APC Troubleshooting: 2 단계, 이미지 1/1
    • Once you’ve done this press the power button to power it down.
  3. M3t Kiosk UPC APC Troubleshooting: 3 단계, 이미지 1/1
    • Once it’s powered down you can unplug everything that might still be connected to it.
    • In most kiosks the UPC will be held in place with a metal plate which can be taken out by unscrewing a hand screw. There should also be a usb similar to the one that plugs into printers plugged into the back of it but that usually falls out pretty easily without you even knowing it.
  4. M3t Kiosk UPC APC Troubleshooting: 4 단계, 이미지 1/3 M3t Kiosk UPC APC Troubleshooting: 4 단계, 이미지 2/3 M3t Kiosk UPC APC Troubleshooting: 4 단계, 이미지 3/3
    • Once you have it out, you can flip it over and remove the bottom plate which will slide out of your way and reveal the battery. Once you get the battery out it should be connected with two cords still that are color coded so you know which one goes where. Remove those cords and the battery should be free.
  5. M3t Kiosk UPC APC Troubleshooting: 5 단계, 이미지 1/2 M3t Kiosk UPC APC Troubleshooting: 5 단계, 이미지 2/2
    • (Continued)
    • Sometimes they may need adaptors and it’s always a good idea to have some handy if you have to go replace a battery.
    • When putting a new one in, it’s very important to make sure that you PLUG THE USB BACK INTO THE BACK OF IT. It’s a huge pain but if it isn’t accomplished you will get a UPC error.
    • Making sure that gets accomplished plug all of the components that need plugged back in back in and plug the power cord back in and replace the plate that held it in place as necessary. After accomplishing this turn the two switches at the top left side back on and press the power button on the UPC and you should be ready to go.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Timothy Morse
회원 가입일: 12/30/15
1,198 평판
안내서 6개 작성하였습니다
The Curo Group The Curo Group 회원
Community
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 170
