주요 콘텐츠로 건너뛰기
MNT Reform SSD Replacement
필요한 것
  1. MNT Reform SSD Replacement, Remove Bottom Plate Screws: 1 단계, 이미지 1개 중 1개
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. MNT Reform SSD Replacement, Remove Bottom Plate: 2 단계, 이미지 1개 중 1개
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. MNT Reform SSD Replacement, Remove Battery Cells: 3 단계, 이미지 2개 중 1개 MNT Reform SSD Replacement, Remove Battery Cells: 3 단계, 이미지 2개 중 2개
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
  4. MNT Reform SSD Replacement, Remove SSD Screw: 4 단계, 이미지 1개 중 1개
    • Remove the single M2×4 pan head screw securing the SSD to the motherboard.
  5. MNT Reform SSD Replacement, Remove SSD: 5 단계, 이미지 3개 중 1개 MNT Reform SSD Replacement, Remove SSD: 5 단계, 이미지 3개 중 2개 MNT Reform SSD Replacement, Remove SSD: 5 단계, 이미지 3개 중 3개
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its M.2 socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the SSD.
결론
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Neelfyn
회원 가입일: 05/13/14
972 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 21
전체 시간: 616
