주요 콘텐츠로 건너뛰기
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
필요한 것
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: 1 단계, 이미지 1개 중 1개
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 3 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 3 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 3 단계, 이미지 3개 중 3개
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 4 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 4 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 4 단계, 이미지 3개 중 3개
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 5 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 5 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 6 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 6 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 6 단계, 이미지 3개 중 3개
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 7 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 7 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 7 단계, 이미지 3개 중 3개
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 8 단계, 이미지 2개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 9 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 9 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 9 단계, 이미지 3개 중 3개
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 10 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 10 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 10 단계, 이미지 3개 중 3개
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 11 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 11 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 11 단계, 이미지 3개 중 3개
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 12 단계, 이미지 3개 중 1개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 12 단계, 이미지 3개 중 2개 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 12 단계, 이미지 3개 중 3개
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 13 단계, 이미지 1개 중 1개
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
결론
To remove the replacement faucet, follow steps 1-6.
작성자
1다른 기여자 명과 함께
Manahal Khalil
회원 가입일: 09/11/21
217 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 24
전체 시간: 1,095
