주요 콘텐츠로 건너뛰기
MSI Force GC30 V2 Vibration Motor Replacement
필요한 것
  1. MSI Force GC30 V2 Vibration Motor Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
  2. MSI Force GC30 V2 Vibration Motor Replacement: 2 단계, 이미지 3개 중 1개 MSI Force GC30 V2 Vibration Motor Replacement: 2 단계, 이미지 3개 중 2개 MSI Force GC30 V2 Vibration Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
  3. MSI Force GC30 V2 Vibration Motor Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
  4. MSI Force GC30 V2 Vibration Motor Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
  5. MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 5 단계, 이미지 3개 중 1개 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 5 단계, 이미지 3개 중 2개 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 5 단계, 이미지 3개 중 3개
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
결론
작성자
2다른 기여자 명과 함께
Matthew Harber
회원 가입일: 02/26/24
503 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 13
전체 시간: 309
