주요 콘텐츠로 건너뛰기
MSI GE62 6QF Apache Pro Battery Replacement
필요한 것
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: 2 단계, 이미지 1/1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: 4 단계, 이미지 1/3 MSI GE62 6QF Apache Pro Battery Replacement: 4 단계, 이미지 2/3 MSI GE62 6QF Apache Pro Battery Replacement: 4 단계, 이미지 3/3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: 5 단계, 이미지 1/2 MSI GE62 6QF Apache Pro Battery Replacement: 5 단계, 이미지 2/2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: 6 단계, 이미지 1/3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: 6 단계, 이미지 2/3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: 6 단계, 이미지 3/3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Justice Owens
회원 가입일: 09/26/17
589 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G3
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 91
전체 시간: 5,880
