주요 콘텐츠로 건너뛰기
MSI GE62 6QF Apache Pro Hard Drive Replacement
필요한 것
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: 4 단계, 이미지 1/3 MSI GE62 6QF Apache Pro Hard Drive Replacement: 4 단계, 이미지 2/3 MSI GE62 6QF Apache Pro Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
    These 2mm screws require a PH #00 screwdriver (vs PH #0 as stated by author).
    DVL - 답글
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: 5 단계, 이미지 1/2 MSI GE62 6QF Apache Pro Hard Drive Replacement: 5 단계, 이미지 2/2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 6 단계, 이미지 1/3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 6 단계, 이미지 2/3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 6 단계, 이미지 3/3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3/3
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
    The 2mm scrrws holding the lower tabs of the HDD plate require a PH00 screwdriver (vs PH0 as stated by author).
    DVL - 답글
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: 8 단계, 이미지 1/2 MSI GE62 6QF Apache Pro Hard Drive Replacement: 8 단계, 이미지 2/2
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
결론
다른 5명이 해당 안내서를 완성하였습니다.
Justice Owens
회원 가입일: 09/26/17
604 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G3
3 회원들
안내서 5개 작성하였습니다
댓글 4개
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - 답글
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - 답글
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - 답글
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 31
전체 시간: 8,190
